Hi Everyone,
I would really like to get the LumoPro 180 Flash and would like to know if anyone has enjoyed this combination the the Fuji Xt-1?
Then secondly I'm not yet comfortable with finding both a wireless trigger, nor shoe cord, but would ideally like both. Not interested in Pocket Wizards at that price. Any suggestions as to what I can use or what would or not work with my above combination?
Many thanks for your time!
Stefan
Hi again!
I have found what seems to be an excellent solve! Very small and beautiful radio triggers for small cameras. Option at $39 with a second receiver option at $55.
http://www.lightpixlabs.com/pages/flashq
2 Reviews here:
http://lavidaleica.com/content/flashq-wireless-flash-trigger-system
http://www.lightingrumours.com/flashq-review-7406
I think my mind is made up on this one. :)
Hi again!
2 Reviews here:
I got the option with two receivers, just one drawback there - I can't get stable sync at 1/180, the black bar already appears at this speed, so need to reduce shutter speed to 160 most of the time. But it may be only my units.
So I have three LP180's and yes I do trigger them with PocketWizards - not what you want to hear.
But I also have a Wein Pulsar Universal IR trigger (Amazon sells them for just over $60) and it works a treat in almost all conditions.  The main reason I bought that was for my X100T which can sync at 1/1000s and the PW's can't keep up at that speed.
But the Wein Pulsar trigger works great with the X-T1 too.
