Hi community,
I switched from Lightroom to CaptureOne a while ago but I was always missing the nice film styles/presets which have been available for Lightroom. So I took some effort to collect and convert them for CaptureOne with rather acceptable outcome. Not perfect, but pretty good the get the style and mood of the old films. The pack includes film styles for Afga, Fuji, Ilford, Kodax, Polaroid and PX. I even created an MSI installer for convenient installation on Windows.
Please test the pack an provide some feedback for further improvements....
More info on this link Capture One Film Styles
Direct download (from GitHub):  CaptureOne_FilmStyles.msi
Cheers,
lolo
  • 3 years later...
Hi lolo,
have to say I can't believe that this has not had more attention as you have done an absolutely incredible job here!
I was in the exact same situation of moving from LR to C1 and really loving it except for missing my film styles pack and finding the native options available for C1 not quite there in terms of accuracy and quality.
I looked all over the place before finding this post and links. What a relief!
Many thanks for your efforts here mate, very much appreciated!
cheers,
LB
