I already have the 90mm F2 and uses it to shoot wildlife/portraiture, very satisfied with the IQ, sharp in focus and creamy bokeh out of focus. During a trail I constantly need to switch between the 10-24 mm and 90mm lens.
I'm considering adding one lens. 56mm is highly praised for portraiture shooting and its samples are stunning. But would the 56mm kind of redundant when I already have 90mm even though it's faster at F 1.2?
I have both, and only rarely use the 56 since I got the 90 three years ago.   But I do not shoot many portraits, mostly landscapes, nature, flowers, cats, and headshots.  I also have the 18-55, and paired with the 90 it is perfect for my hikes.
Edited by merlin
I have the 56mm and love it, but when people ask me about buying one, I always try to throw the 55-200mm out there as a second option to consider for a smaller budget. While the 56mm is my first choice for portraits, the 55-200mm has decent bokeh when shot wide open, is fairly versatile for longer focal lengths, and you can find a good used copy of it for under $500.
4 hours ago, Nero said:
The 23mm f/1.4 is one of my top 2 lenses, but it does overlap with your 10-24mm. If you're thinking you'd like another prime lens and you don't want it to be redundant, I'd say look at the 35mm.
i already have 35mm. here is what i thought. i would take a wide for senery (10-24) and a tele for wild life (90) in my trip.
23mm 1.4 is large. though it can create some magic that 10-24 cannot, most probably i will not carry both in travel. 10-24 is more essential for landscape.
16mm 1.4 can shoot some interesting photos due to its fast aperture. maybe i can pick it instead of 10-24mm in a travel because 16mm is more versatile.
