I have a Fuji X100s and a Nikon SB800 Flash. I want to sync the two - with the flash off camera and take advantage of the leaf shutter on the Fuji.
I've had a suggestion to use the Phottix Ares Flash Trigger and Receiver Set and I wonder if anyone has used this setup or has any other suggestion?
