I propose to influence the head office to make a normal mechanism for selecting the number of time-lapse images in the firmware. Now you need to hold the lever until the counter winds as much as necessary. If you do it wisely, there should be three counters - hundreds, tens and ones. For example, all zeros are infinity. Let's say I need to jump from 330 frames to infinity. I hold the lever for about a minute. Then back. Again about a minute. With three counters, I would have to spend a maximum of ten seconds.
I'm sure it's the same nonsense on other models. I'm really tired of this already!To the left everything is fine with time. It was necessary to make one counter there too so that we would all go crazy...
Before:
For example like this. Or do as with the time on the left. After:
Edited by NikVladi
