Why is Cam Remote not working when it hasn't been used for a few weeks.
And on the rare occasions when it works, it's only for a few photo's, then all the sudden it stop's working and the WIFI connection is disrupted, and my iPhone disconnects of WIFI and switches to G4.
This is my second X-Pro, the fist was an X-Pro2 and now it's a X-pro3, it's my second iPhone (iOS 15.5) too, and each time (regardless the camera ore the iPhone) that Cam Remote app hardly worked as I hoped it would.
I meticulously followed the instructions as described in the User Manual, repeated the setting, I unraveled the internet and even switched to the English version of the menu on the camera to avoid things lost in translation, but alas...
And now it blocks the proper use of the camera aswel the iPhone, it's a mess...
Edited by philippe.debeerst@photoeil
