I also find the Photozone’s 16-55mm lens test results disappointing. However I do not immediately think that this is related to a bad copy or something. It might have something to do with field curvature. Photozone is testing with a flat surface on a relatively short distance. Any field curvature could easily result is lesser performance at the edges and in the corners. This differs from Fuji vs Fuji lens tests as they test against ‘real world’ situations.
I don’t photograph test charts myself therefore I take such kinds of tests with a grain of salt. They are by no means irrelevant though……
It is always best to judge lens performance on several test sites and check out ‘how’ the lens test is performed.
