Fresh from Japan, a brand new XM-FL body cap lens. Came from Yodabashi Camera and was ¥8000. I hadn't much time to play with it due to my work schedule. (The lens has been sitting unboxed on my desk for three days)
I took only 36 shots, one in each of the three modes; clear filter, starburst and soft focus. Being close to sunset, after heavy thunderstorms we've had here in the DC area today, the starburst really look just like, and soft focus, well.... I'll let you judge.
Posted for your bewilderment, three shots, SOOC JPEG (cause, I'm under work deadlines for the paper and don't have time to eff with Fuji's crazy RAF format at the moment). All images came from an X-Pro1, and in the same order as the lens's filters, clear, starburst and soft focus.
Will try to post a formal review complete with RAF files when or rather if time permits.
EDIT: Images are apparently too large to upload, and require resizing.
Clear Filter
Starburst filter
Soft focus
