I’m embarrassed to ask. I’ve gone through the menus and controls. But, I’ve evidently set the camera to display the most recent picture in the viewfinder or LCD just after I take a picture. I’m so embarrassed, but I can’t seem to find the menu command to stop this. No you know why I like the hidden LCD on my XPro-3 ;) In the meantime I’ll continue to scroll the menus!
Setup Menu - Screen settings - Image Display will disable Image review for all but one particular configuration.
The exception is if your VIEWMODE is set to Eye Sensor + LCD Playback, where upon you'll get plaback if you shoot via the EVF then take the camera away from your face.
30 minutes ago, mawz said:
The X-T2 does, which I tripped over recently.
I'll try my Pro-3 and see if this does the same. Of course most of time I've got the LCD in hidden "stealth" mode ;)
