Now that this camera has become very cheap, I have been thinking of buying one a couple of times and like me several people might have done so but I wonder if tis aspect of this camera is clear to everyone.
I never heard this before but as I was reading a test of the 90mm ( carried out with the X-Pro-1) on Jason Pitcher’s blog, my eye fell upon a comment which sort of horrified me ( although once it sunk in it is pretty logical that it is this way) but the OVF doesn’t work with lenses longer than the 60mm ( and I suppose shorter than something else perhaps the 18mm?).
Not that it is terrible ( since there is a EVF)  but it is worth thinking about it before buying.
I acquired the 90/2 a few days ago and I too was surprised not to be able to use the OVF with it: you pull the front side lever, and nothing happens, you remain in the EVF. Then I figured that the focal length was probably too tight for the frame lines to display in any kind of useful manner in the OVF, probably because magnification cannot change to make the frame more discernible.
It's strange, though, because the OVF is perfectly usable with the 55~200...
Maybe that will be addressed in the X-Pro2 OVF. At least, that would be a welcome improvement in my opinion. I've gotten sort of used to using the EVF with the 90/2 but I definitely like it a lot less than the OVF.
This is not a problem as it relates to the use of the camera.  The camera still works, although with out the use of OVF, of course.  I personally don't think they intended the camera to ever be used with zoom lenses or any focal length outside the normal range.  Perhaps with the X-Pro 2 they will have a switch, like analog rangefinders did, or something.
Having tried to use a Leica M6 with a 135mm lens in the film era, you really don't want the OVF to reach too far into the telephoto. The bright frame for 135mm is tiny in the viewfinder, magnifiers never seem to work as well as you would expect, and parallax errors plague your picture taking, no matter how good the parallax compensation system.
All I'm saying is this is the nature of rangefinders.  Everyone who's ever shot one knows this.
I understand what you are doing and I appreciate you bringing this up.
With the success of the X-Pro1, I have no doubt that this will be something that Fuji addresses in the X-Pro2.
I agree 100%. The RF cameras were never designed for long lenses or zooms. It's unrealistic to try to force them into the mold of a reflex. There are plenty of EVF and SLR cameras, if that is the way you work. The fact that the X-Pro1 does a credible job with lenses outside the range of the OVF is a credit to its design and a plus for the owner. If you think that's inconvenient, try using a Visoflex on a Leica!
Once Again :rolleyes: , I didn’t start this thread for those who have the benefit of their superior knowledge or intuition and know all along that this not possible.
I have a fair bit of experience and yet didn’t realize this until I saw it, so I started this thread as a warning for those who, not gifted with experience, intellect of deductive capability might have unwittingly not realized this.
This thread is a warning to those folks.
If you didn’t need the warning or to be told any of this, I am very happy for all you... this thread is for the rest of us.
So, should you find it useless, please, disregard.
Milandro, take it easy. You are one of the most active persons in this forum. You should already have got used to this kind of discussion.
If someone has a question like "Can I do A with my X" you can be sure there are replies like
- Why do you want to do A. Doing A is stupid. Do B.
- No one ever buys X to do A. You should have bought Y to do A.
- You can do C. It is not the same as A but C is great.
Another alltime favorite for is:
- I don't have the answer, but would be interested in the answer as well.
This is what we have to expect when we post. So just ignore it.
