My X-T4 arrived yesterday - so far I have been very impressed! The size and weight was not too much greater than the X-T2 I've been using.
My question is about recommended accessories.
I've become quite accustomed to a thumb grip (I've used Lensmate products and been very happy with them). Does anyone know if or when they will be releasing one for the X-T4? Or, are there suitable ones on the market now that would fit the new body shape (the Lensmate from the X-T2 does not fit over the rubber eyecup on the X-T4)?
I also enjoy the Gariz half leather cases - but I can wait for that, it's purely aesthetic.
Thanks for any advice you may be able to offer!
