The 22MB are compressed. Not all software handles them yet.
Is there a list floating around anywhere that shows which software currently supports the compressed raw files?  I am trying to decide if I should shoot compressed or not but don't want to end up with something unsupportable down the line.  Otherwise, shooting lossless compressed seems like a no-brainer.
Capture One definitely doesn't :-(
