Nice new topic?
Post a photo of yourself with your Fuji.
I wil be the first one   ;)
…with an X-E2 for a change  B)
XT1 + 35
My first fuji combo.
Still my favourite despite have an xe2 and a few more lenses now.
Me and my fuji XT-1
X-pro1 fitted with the Voigtlander Nokton 50mm f/1.1.
Here's mine!
Hi!
Hello Mirror ^^
Me and my X-E2 with XF 16-55 F2.8.
Quite a big lens ^^
Cheers
Tom
X-E2 & Nikkor 85/1.8 :wub:
X-T1 in Cambodia :)
me and my XT1 practicing with Double exposure
  • 1 year later...
OK, I give in!
Canons of beauty by Giovanni Gastel.
